(quoted from post at 14:00:45 02/18/20) Will my Ford 8n pull a 5 ft rotary cutter or bush hog with problems? And yes I have the overrun clutch.
(quoted from post at 12:00:45 02/18/20) Will my Ford 8n pull a 5 ft rotary cutter or bush hog with problems? And yes I have the overrun clutch.
The only problem is you don't have live hydraulics. You can't raise the cutter unless you have the PTO engaged. There are times where you might have to shut the tractor, get off, take the PTO shaft off, then start the tractor and raise the lift. Doesn't need to be done often but it does happen.(quoted from post at 12:00:45 02/18/20) Will my Ford 8n pull a 5 ft rotary cutter or bush hog with problems? And yes I have the overrun clutch.
(quoted from post at 10:32:19 02/20/20)The only problem is you don't have live hydraulics. You can't raise the cutter unless you have the PTO engaged. There are times where you might have to shut the tractor, get off, take the PTO shaft off, then start the tractor and raise the lift. Doesn't need to be done often but it does happen.(quoted from post at 12:00:45 02/18/20) Will my Ford 8n pull a 5 ft rotary cutter or bush hog with problems? And yes I have the overrun clutch.
