(quoted from post at 16:14:46 02/16/20) HiYa Otto-
I'll agree that you don't have to contact a mechanic if you are capable of doing basic mechanical and electrical work yourself. The best investment you can make as a newbie is to get copies of the Essential Manuals and read religiously. Know what you are getting into so you don't hurt yourself or a part of the tractor. I see a generator so that means it should still be 6V/POS GRN which is good. Your issue sounds like a fuel problem but don't guess and don't buy any new parts not knowing if old is defective. I'd start with a fuel flow test. It's simple, easy, and takes less than half an hour. With tractor OFF and engine COLD, get a drip pan or empty coffee can and place under the carburetor. The Fuel Sediment Bulb Valve should be shut off when tractor is off. On the bottom of the carb is an NPT drain plug. Loosen and remove it. Position pan under it and open the fuel flow valve 2 turns. Observe the fuel flows at a steady uninterrupted stream about as thick as a pencil. You should have about a 1 pint of gas in 2 minutes. If so, turn valve off and replace the drain plug. Next, use a 7/16" flare nut wrench and loosen the steel fuel line at the carb inlet brass elbow. Gently take the line off to the side of carb and point down to the drip pan. Again open valve 2 turns and see if flow is free or obstructed. An obstruction can be caused by the filter on the brass elbow, remove and inspect and clean it, or the sediment bulb and/or screens are plugged, or the vent on gas tank i plugged, or all of the above. Take an hour out of your busy schedule to check this first. You can do much of the PM yourself on these N's. I understand about work and home schedules and not having the time, but a mechanic will cost you $50 an hour and that is a cheap one. Report back with results and we will discuss when we cross that bridge.
Probable NO-GO fuel issue causes are: plugged vent, plugged screens, plugged sediment bulb, dirty gas tank, dirty carb, and more. There are three OEM screens in the fuel system. Two are on the Sediment Bulb Assembly; the 3rd is on the brass elbow inside the carb where the fuel line connects to. SEE PICTURES. I wouldn?t be shoving anything, wires especially, up into the sediment bulb assembly. You have a vertical fine mesh screen on the inlet port inside the tank that you can damage. Best solution is to remove the tank and thoroughly clean. The ESSENTIAL MANUALS are your friend. PM is so important to maintain any piece of machinery.
FORD N-SERIES TRACTOR FUEL SYSTEM & POSSIBLE CAUSES OF NO FUEL:
<center><img src="https://i.imgur.com/aYjnNhrh.jpg"></center>
<center><img src="https://i.imgur.com/5kg5WXLh.jpg"></center>
<center><img src="https://i.imgur.com/6javxgvh.jpg"></center>
<center><img src="https://i.imgur.com/v8ej8sZh.jpg"></center>
<center><img src="https://i.imgur.com/cpzSswah.jpg"></center>
FORD 9N/2N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
<center><img src="https://i.imgur.com/i2gbSeol.jpg"></center>
Tim *PloughNman* Daley(MI)
