DSJ6811
New User
New to this forum but have learned enough to from you guys to be dangerous so far. I have 51 Ford 8n and have converted to 12volt system. I have always noticed sometimes my starter didn't engage right away so I checked the ringgear and found some worn spots. I still work fill time and have 5 young kids so am trying to get some money saved before changing it out this summer. I guess what I am asking is what else should I plan on changing while I have the tractor split. My clutch is strong but do have some leaking from front and rear main seals. Thanks for all the help so far
DSJ6811,I would try a new style starter drive first as they engage so much better.
Drive
(quoted from post at 12:51:27 02/16/20) New to this forum but have learned enough to from you guys to be dangerous so far. I have 51 Ford 8n and have converted to 12volt system. I have always noticed sometimes my starter didn't engage right away so I checked the ringgear and found some worn spots. I still work fill time and have 5 young kids so am trying to get some money saved before changing it out this summer. I guess what I am asking is what else should I plan on changing while I have the tractor split. My clutch is strong but do have some leaking from front and rear main seals. Thanks for all the help so far
Not much you can do during a split about the front and rear seals leaking, but you can replace the front seal on the trans and the throw out bearing and the pilot bearing.
