HighSierra86
New User
I will start by apologizing for even bringing this topic up again. I have been reading for the last few days on multiple forums about the topic of which oil to use in the N-Series/Ferguson trans, hydraulics, and rear end. Yet I still have some unanswered questions...
For years we have used Ford 134 oil (technically using the NAPA brand 85-405) in all our N-series tractors. A while back I had done some hyd system repair to our 2N and tried to use the 90W GL1 straight mineral oil from NAPA (65-205). I understand it may work in some areas of the world but it was wayyy to thick in my opinion. Just filling the tractor was a seemingly never ending project waiting for it to leave the pail and then settle into each sump. The winter performance is painfully slow, and sometimes I have to sit with my foot on the clutch until the engine warms up enough to even churn it over in the rear.
I just finished rear axle seals in a TO30 and I am curious about trying the 15w-40 engine oil. I know I can use the 134 as it is yellow metal safe, however I am wondering if the 15w-40 would be better suited for the worn internals.
My question is this....For the guys running 15w-40 in place of the UTF or GL1, what oil are you using?? A lot of the threads I read mentioned low or non detergent 15w-40 formulated for gasoline engines only. Why? I cant say I have seen anything like that in the states. Most of the threads were also over 10 years old and I know the diesel oil formulas have changed since then. I have a 55gal drum of Rotella 15w-40 T3 that I would love to use if possible.
So before I get into a hurry and dump the UTF in...anyone have some newer info to share on their experiences?
Thank you,
Nick
Thank you,
Nick
