Cylinder Sleeve Puller
PopsH
Anyone know where to obtain a cylinder sleeve puller/installer for a 2N engine with standard bore and .04" sleeves? My valve, ring, and clutch job has morphed into a complete engine overhaul. I found some sleeve pullers on eBay, but none that looked like they would work well on my old Ford. Thanks.
(quoted from post at 14:46:00 02/11/20) Anyone know where to obtain a cylinder sleeve puller/installer for a 2N engine with standard bore and .04" sleeves? My valve, ring, and clutch job has morphed into a complete engine overhaul. I found some sleeve pullers on eBay, but none that looked like they would work well on my old Ford. Thanks.
I am currently booked solid but you can buy a puller almost identical to the ones I make from Just 8Ns.
TOH
Thanks much, Mr Cooke, but I work slowly! Plus, I have another Ford tractor to rebuild after my current one, and wouldn't be comfortable borrowing your sleeve puller for the length of time I'm likely going to need one.
