Re: Rear axle preload - axle won’t turn
chrislee85
02-11-2020 19:08:32
I have a set of shims that should be here tomorrow. I realize it makes logical sense to add one to one side then one to another until it is adjusted accordingly, but what could be damaged if they were just added to one side?
Bob
02-11-2020 19:44:10
 Re: Rear axle preload - axle won’t turn in reply to chrislee85, 02-11-2020 19:08:32
You are OBSESSING over this.
You are dealing with BIG slow-turning tapered roller bearings.
Unless they are big-time pre-loaded, or have LOTS of play, they will outlive all of us.
Grab the wheel flange at either side and yank it "in and out".
If there's a little (correct) endplay of around 0.005" you will feel and HEAR that little bit of movement.
