All. Thought I would do a tune up on the tractor and made it worse. Have gone through the manuals and guides and I am still not figuring out what I may have wrong.
Here is what I did. Took off the carb and rebuilt it with a kit, making sure to carefully set the float level.
Replaced the spark plugs.
I was very careful to record the number of turns on the carb for any pins I took out.
Here is my problem. It runs just fine however under a load it will run for a bit, then stumble and quit on me. Which to me sounds like I am running out of fuel.
Thoughts?
Thanks.
Eric.
Thoughts?
Thanks.
Eric.
