Jubilee live pto shudder
Dustyah
Pops has a 1953 Jube, has the live pto option, hydraulic lines run back from the pump, he drained and filled rear end, took out nasty 90 wt and water, put in hy-trans, he claims now live pto shudders, is this a thing, guess the live pto clutches don't like hy-trans, so back to 90 wt, anyone have any experience with this thanks dusty
(quoted from post at 21:40:31 02/02/20) Pops has a 1953 Jube, has the live pto option, hydraulic lines run back from the pump, he drained and filled rear end, took out nasty 90 wt and water, put in hy-trans, he claims now live pto shudders, is this a thing, guess the live pto clutches don't like hy-trans, so back to 90 wt, anyone have any experience with this thanks dusty
IIRC the live PTO is a dry clutch.
TOH
(quoted from post at 23:38:35 02/02/20)
TOH
On second thought I'll retract that.
TOH
The NAA has three separate compartments, transmission, hydraulic. and rear end (differential. )The live PTO clutch on a NAA runs off of the hydraulic oil. We drained the rear end!!! It is time for more specific information.
I suggest you investigate the true root cause problem of getting water in your hydraulic system first. Do you have the OEM Manual?
Tim *PloughNman* Daley(MI)
