NewOldFarmer
Hi all, I finally got my 8n running again. I'll post a pic in a minute... Two issues now that she is running again. I filled my Radiator started her up and she is running pretty smooth. BUT after she runs for about 4-5 minutes I start to get water coming out of the radiator cap. The way it is shaped it shoots water right back at me the small overflow tube under the hood is pinched off (I don't know if the water is coming from there or not), but I never had any problems before I took it all apart. I did put the thermostat in, but that was a while ago and don't remember which way I put it in.... I assume I put it in right, but that is the only thing I touched on the cooling system. If the thermostat was backwards would that cause the water to shoot out the top?
And my second issue is the steering.. Tearing It down to replace the Ring gear, I had to remove all the steering arms. Now I can turn to the left but I can't go past straight when I try to go right. I think the arms need to be attached opposite position of each other? Any ideas.
