I have to choke my 8n carb when pulling a hill
Satohbill
What adjustments to carb do I need to make when I have to pull my choke out to keep engine from starving when pulling a hill?
Satohbill,Colder winter temps require a richer fuel mixture.Open the main jet adjustment 1/4 - 1/2 turn and see if that helps,
If what Den said, doesn't help, come back. Your tractor is running too lean and if it's not the main jet adjustment it could be fuel flow or a vacuum leak.
