[size=18:7307cbe4a8][/size:7307cbe4a8]
Well.....the snowGod decided I needed a little bigger snow cake....SOOOooooo, after getting 6-7 inches of the 'Global Warming'....Here is the 'New' snowcake!!!! (SAME OLE TABLE THO!!)
Looks like plow day will be in the sched. for snow removal, in the upper drive, and frt. parking area!!!!
B.G. (the ford 3000), was having a little trouble with scooting around on the thick Ice, for the last plow day, and since His chains, have not gotten here yet......I built a platform on the rear blade to hold 7-8 sandbag weights, just to the rear of the Three point hitch. Gave him approx. 275 lbs. more for the rear tires. I already have 240??? Lbs with the 'FORDMOCO' cast iron wheel weights, on each rear side axle.
Sure did help with traction, and when the chains get here....B.G., should be set up just fine!!!.....(I HOPE)!!
Here is a couple of pix.....B.G., with the added weights!!!
Gary
Gary
