Larry Kastens
I bought a 12 volt conversion but the company did not include the directions. The kit has a one wire alternator, a 12 volt coil, a ballast resistor, and the necessary wires and brackets. Could someone point me to a simple wiring diagram that uses a four post starter solenoid? There are many diagrams online but I can not find any large enough to print that shows the four pole starter solenoid. Does a person need the old terminal block with its own resistor?
I also installed a starter button. What size should be the 12 volt wiring? Thanks to anyone who responds.
