I?m pretty sure the tractor is A 2n it?s a three speed transmission and
at first I thought it was stuck in between two gears you push the
clutch down it stops but when you let it out it goes but real hard pop
the top off the transmission and everything looks good. Even in
neutral it still does the same thing or shifting it into another gear.Is
there a shaft in the transmission that can be frozen not moving doing
this not sure what my next move is? Thanks Ernie
