Lynn Patrick
Thought I'd show how!
1st pic is the 1 1/4" sink drain in the tub.
2nd is the 2 pails w/the drain in the spout of the 1st. It settles out the large pieces & fluid runs off the top thru another sink drain into the second.
3rd - the second pail drains out about 1/2 way from bottom, runs thru a diesel tank filter, then to the HF pump.
4th is a piece of rubber mud flap where the switch used to be, absorbs any vibration from the pump to the original flexible tube.
No liquid stays in the tub & pump is easily replaced if ever needed again, & BOY does it work great!!
