Hey everyone, I have an 8N tractor that was converted over to 12 volt but the resistor wasn't hooked up. I found it has a melted coil, a
melted condenser, and melted points. Is the resistor what caused this ? Also the screw hole that holds the condenser down is bad, but I can retap it. Would the loose screw cause it. The key is never left in the on position on it. Thanks in advance.
