Marvel Schebler Carb
I was having a little trouble with my carb and decided to rebuild it. I took it off and cleaned the gunk off of it to start the cleaning process and noticed that there was a very small crack extending from the carb drain screw. I looked and could not see where it had been leaking but it was so dirty it might not have been leaking because of all the dirt and grime. I sprayed some carb cleaner down into the carb and I could see that the crack was starting to leak.
I said all that to ask this. Can the crack be fixed somehow or will I need to find a different lower bowl?
(quoted from post at 21:35:10 01/07/20) I was having a little trouble with my carb and decided to rebuild it. I took it off and cleaned the gunk off of it to start the cleaning process and noticed that there was a very small crack extending from the carb drain screw. I looked and could not see where it had been leaking but it was so dirty it might not have been leaking because of all the dirt and grime. I sprayed some carb cleaner down into the carb and I could see that the crack was starting to leak.
Get a replacement bowl or carb - used ones are dirt cheap.
TOH
