Any suggestions for a gauge type that similar in writing and script to the OE gauges for a later model for 8n. I m completely rewiring the tractor with a single wire alternator conversion etc. Also going to install a temperature gauge (head already drilled and tapped). I see no real need for a amp meter so I m ok with converting that to a voltmeter. Water temperature and oil pressure are far more important. I do want to have a set of gauges that are back lit so if you use the machine at night you can see exactly what all the gauges are saying.
If you have any suggestions as far as gauge brands/types that would be fantastic. Thanks.
