Gearbox manufacturing
Matthewo1
New User
Hi there is there anyone out there that can manufacture a reduction gearbox Sherman live pro ?
Apparently this would fit a ford and or fergie to give live drive.
Or may be someone has one for sale
I?m sure I read on here someone was trying to fabricate the unit ???
(quoted from post at 18:05:22 12/03/19) Hi there is there anyone out there that can manufacture a reduction gearbox Sherman live pro ?
You are [probably thinking about this. It is a ground speed gear reduction mounted to the rear of the transmission similar to a Howard - not a live PTO. With all of the other things I have going completing it is way down on my list.
TOH
Ns are great small tractors that will still do a lot of useful work for you.
But the reality is you will not add live pto to one. And you'll probably not slow one down enough to use on a tiller without spending a bundle of dough.
Think outside of the box. If you want a tractor with more features then buy one with more features. Ford 3000s could be optioned with tiller capable 8 speeds, power steering, differential lock, live pto, they all had live hydraulics, much more hydraulic capability and a diesel engine that put out more horsepower hours per gallon of fuel than an N would. And they are cheap and plentiful. You will pay less for a decent running 3000 than you will to restore an N and Way less than restoring an N and then trying to add the features you asked about.
Use your N to do the jobs it was designed to do. If you need it to do more then buy a tractor that was designed to do more.
You'll get more bang for your buck that way.
Your planetary gearing reminds me of the Epicyclic auxiliary Trans.
<a href="https://imgur.com/XJirToz">
XJirTozm.gif" title="source: imgur.com"
</a>
(quoted from post at 05:19:29 12/06/19) Your planetary gearing reminds me of the Epicyclic auxiliary Trans.
Epicyclic is the engineering term for a planetary transmission. Mine is a typical reduction design using a fixed annulus, sun gear as input, and planet carrier as output - overall reduction of 3.5:1. I was initially contemplating five planets but with my tooth counts that complicates the planet spacing so I dropped back to 4. What transmission is that in your picture and what was it used in? Looks very similar to the arrangement I had in mind for the N's?
TOH
It's the ferguson epicyclic gearbox. Never seen one on this side of the pond.
<a href="https://imgur.com/d887dvA">
d887dvAm.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/VEy13Ud">
VEy13Udm.jpg" title="source: imgur.com"
</a>
(quoted from post at 04:54:03 12/07/19) It's the ferguson epicyclic gearbox. Never seen one on this side of the pond.
&lt;a href="https://imgur.com/d887dvA"&gt;&lt;img src="https://i.imgur.com/d887dvAm.jpg" title="source: imgur.com" /&gt;&lt;/a&gt;
&lt;a href="https://imgur.com/VEy13Ud"&gt;&lt;img src="https://i.imgur.com/VEy13Udm.jpg" title="source: imgur.com" /&gt;&lt;/a&gt;
I have never seen that before. Very interesting - looks like it used a different design that allowed the annulus to rotate with a brake band to clamp it stationary when shifted. Harry also cheated - he extended the tractor to make room for it
TOH
(quoted from post at 08:16:46 12/07/19) Some more pics
Ferguson gear Box
Thanks, I found lots of stuff about it when I searched yesterday. I wonder why Ferguson never went mainstream with that. Its much better than the Rube Goldberg mess Howard made for the N-series tractors - hence my effort. Perhaps the less complicated and I am sure much less expensive planetary Howard made for the NAA and later models put the kebash on it.
TOH
