'48 8N, went to plow snow, and it would run only with the clutch in. Otherwise, the trans was locked up. Thought about water in the oil.... eventually got it thawed out and in the shop, sure enough. Changed the oil, put in TSC 'Renew'. Then the hydraulics would work, but had no position control, even with the lever up/vertical. Put the quadrant to raise the blade, and it would go completely up even if you put the quadrant lever back down. Same with lowering it. It would only stay all the way up, or down.
Soooo, pop the inspection plate, and with the quadrant all the way down, see photo 1.
Raise the quadrant and it moves forward and contacts that rod coming out of the pump at about 2/3 of the way up, but the rod is frozen in place (engine off). Quadrant can be put all the way up, but there's some resistance. Loosened the 4 quadrant bolts and tapped it as far back as it would go, that helped a bit but not nearly enough. Photo 2.
I'm thinking there is a problem with the cam follower pin up in the top lift cover because the rod that goes from there to the pump is so way out of whack. Also, should that rod at the pump end that it pushes on be able to move? I can't get it to budge even reaching in there and pushing. Any ideas would be much appreciated before I start diving in!
(Yes, that yellow stuff is the brand-new oil).
