Yes it is. On the left side cover take the bottom bolt out. When oil comes out the transmission is full.(quoted from post at 03:42:42 12/02/19) Is the transmission, rear end, and hydraulic system all the same oil in my 1952 8N? Filled near gear shift
(quoted from post at 06:20:31 12/03/19) HiYa Jim-
CNH no longer makes and sells the Ambra Ford 134 oil. They only supply the modern stuff made for their newer NH Boomer Models.
I switched from 90w to UTF and now, when plowing snow, the lift is usable immediately. I used to have to wait 5 minutes or so for the 90w molasses to warm up.(quoted from post at 08:25:49 12/03/19) I really like the cold weather performance of the UTF here in VA; I'm surprised that you use 90w in MI.
TSC UTF works better for me in VA than the NAPA gear oil.
75 Tips
(quoted from post at 11:33:35 12/13/19) Hey guys,
I changed my fluids several months back using UTF. I have a slight leak at my weep hole area and need to add more fluid. Would it hurt anything to add the SAE 90 to the UTF? Just looking to try to slow up the leak a little and wasn't sure if mixing them would hurt anything.
(quoted from post at 14:03:48 12/13/19) Thanks TOH,
How bad of a job is it for a rookie to replace the seal?
