Been making posts here and there about advice on this old machine and figured I might as well put this thread together. Grand dad owned this tractor and when he died in the early 80 s and Grandma went to live an apartment this old tractor went down to my parents farm.
Learned to drive on this old machine. Spent a lot of time running wagons, raking hay, tedding hay, cleaning barn and even skidding logs out of the woods with this old machine. Engine had a major overhaul done in the early 90 s. In the early 2000 s the oil pump pickup cracked and the oil pressure plummeted and my dad quit using it. At the time I was stationed (former Army) within driving distance of my parents place. Brought the machine back with me. It needed a crank (original had already been turned .030) and bearings but everything else seemed serviceable.
Dad retired farming heavily about 5-6 years ago but still does odd odd jobs with it. Still had a handful of horses still and widdled it down to having one left.
Anyways, this past fall my parents barn caught fire and burned down. Lost two Farmalls (450 and M) plus a host of implements tools etc. The little Ford was not thankfully in the barn but due to just how hot the fire was it burned most of the right side tires off the tractor. Collapsed/warped the air filter casing, damaged the hood, damaged both the front and rear rims on the right side, melted all the particulars with the distributor, and other such damage including all the wiring.
Stupid stuff I broke so far:
I remember back in the 90 s when we were overhauling the engine I broke the coil mounting bolts off in the head. We just rigged up a way to mount the coil off the timing cover bolts. Worked but wasn t OE. Well stupid me decided to try to weld a nut on one of the broken bolts while I have the hood and everything off. I cracked the head. Great... $250 later we are back in business with a used head from EBay, new head bolts, head gasket, and having the local machine shop check it out, and planing .013 off to true it up.
Items we ve fixed so far:
Put all new rubber on the front.
Replaced the rims on the right side
Replaced the right rear tire.
Replaced the distributor.
Replaced all the plug wires and coil.
Items to get fixed:
Carb leaks fuel like crazy needs rebuilt.
Find a new hood and dog legs.
Steering has a nasty grind in it. Probably all the lube is gone.
Hydraulics haven t worked right for the last couple of years. Once I get it running sort that out.
I ll post updates as I get things done.
Items to get fixed:
