Wagner WM4 Loader front bracket
2N Bob
New User
I have a WM4 loader that is missing the front mounting bracket. I have a diagram from the manual but there are no measurements. Does anyone have measurments (height, length, width) and/or pictures that would help me get one made?
From other discussions it sounds like TheOldHokie might have parts available for loaders. If so how can I contact you? Thanks. 2N Bob
TOH is deffinately the man you need to see.
if he don't see this message post a message specifically to him.. call him out.. and leave your email open so he can contact you.
I've gotten hold of him that way when trying to track some laoder brackets down for a person i was helping.. etc..
soundguy
Check this site out. He has a measured drawing.
I built one, two weeks ago and it worked perfectly. Look at the bottom of his 2n page.
I love my 8n w/ a loader,beats the hell out of shoveling.
John
Untitled URL Link
Like this, I have some drawnings mail always open
TOH here. Which bracket do you need? There were at least three different ones. The first two shown below pretty much interchange although the second one is probably more robust.
1) I have gobs of these ones:
2) I have this drawing for the later style but have not made one yet - it's on my to do list:
3) I do not have the one Hobo posted which also doubles as a mounting point for the pump but with a drawing anything is possible....
TOH
Hi, I know this is an old post but I am having the same issue. I really need the plans for the loader bracket to get my loader going on my 9n. I know you posted the drawings but photo bucket has blurred them unreadable. I would really appreciate it if one of you guys could re post or pm me the drawings.
thanks a ton
(quoted from post at 18:23:21 11/08/19) Hi, I know this is an old post but I am having the same issue. I really need the plans for the loader bracket to get my loader going on my 9n. I know you posted the drawings but photo bucket has blurred them unreadable. I would really appreciate it if one of you guys could re post or pm me the drawings.
thanks a ton
The WM4 style hanger will not work on a 9N. Your best bet is to use one of my hangers and bolt/weld a bracket for the pump to it.
TOH
(quoted from post at 16:07:07 11/08/19)
TOH
Ok I was thinking I had a wm4 for a minute but its actually a wm3. The guy I bought it from took it off a 9n but cut the brackets instead of working the striped bolts out. I was reading the manual and need the bracket that is in the attached picture. I assumed the first technical drawing in your above post was the same one.
any help appreciated
(quoted from post at 19:36:51 11/08/19)
TOH
They are available for purchase - email me: [email protected]. You will need to drill a 1/2" hole in the front axle support for the attaching bolt. Other than that it is plug and play.
TOH
