bush hog...
(quoted from post at 07:06:11 10/23/19) junk ?
parts availability ?
needed to cut small deer plot.
_________________________________
Based on a rusty 5' MF I bought for $200, I'd also check that the gearbox is holding its oil. I repaired the broken gearbox end cap and replaced the seal. I sharpened the blades without removing them from the blade bar and replaced the tail wheel post and bearings.
Pull?
Yes.
Will it cut a 6' swath in most of the
stuff guys use them for? Probably not.
Will it lift, heft and carry a 1500 lb
Bush Hog? ?
No.
As our dear departed friend and tractor
guru Dell used to say:
Your front tires would be flappin in the
breeze.
