MonkeeRench
New User
After years of excellent starting behavior, my 9N suddenly wouldn't start at all.
I removed and reconditioned the distributor and the carb. At first it then would start and run with the choke pulled half-way, but only for a few minutes. Sparking tests seem OK.
I then removed the inline gas filter and leaky hose and installed a new (aarrgh) sediment bowl-w/valve and a steel gasline and new in-carb connector-filter. It was a pain minimizing the leak thru the sediment bowl gasket, but it now [u:a92960ab68]seems[/u:a92960ab68] manageable(?). My three attempts with different O-rings failed to be any better than (non-cork) material.
It now runs long enough (without any constant choking) and sounds good enough to do main needle & idle needle adjustments, initially responding nicely to changes in the throttle level. But before it is about to die (gas-starved?), there is no response at all to throttle-advancing.
I have measured the gas flow out of the carb bottom-drain to be close to 9 oz/min over 30 minutes, and the flow rate directly from the gasline to be close to 15 oz/min, also over 30 minutes, with very similar results over 3 minutes.
During the flows, there did not seem to be any air-bubbles forming in the gasline, although I could barely see a possible bubble in the top of the sediment bowl, but that didn't [u:a92960ab68]seem[/u:a92960ab68] to interfere with the flow. The filters have remained clear.
When I removed the carb again, I readjusted the float to be 1/4 inch offset from the metal [u:a92960ab68]surface[/u:a92960ab68] for the gasket rather from the [u:a92960ab68]gasket surface[/u:a92960ab68] of the material. The starting behavior has still been the same.
I am thoroughly puzzled and would appreciate any suggestions.
