if it help,s my Evaluations: I paid top dollar for a new dist. camshaft assembly, to me high at + $90 and discovered the throw slots, although reversed in the advance
were advertised to work the same on the "net". not the package! I was not going to use it after I also obtained another one for under $30 from Amazon (slots correct
angle). In comparison at full disassembly of both I saw no real advantage to the extra cost. Neither had a wick in a hole I know of for the top bearing. So I put the
china one in my Mill and put a hole from the drive end to the cross spotted hole and fixed that. I then tapped the drive end plug hole 1/16-NPT and inserted a used
Wick and flush mount 1/16 NPT set screw. Soaking the daylights out of it with oil for days, after it was in and before plugging it. Even the original Ford parts are
not full hardened but case only? (I have discovered in the past on this particular little part, center and exterior are machineable). Lacking a Rockwell test who
really knows what QC was?
These Front Mount dist. are truly Opposed Axis rotating shafts, self-contained in rotation with self supporting bearings for each. Since they are bushings and not
Conrad's is asking for or is prone to need more attention. It is all also driven by a off center or eccentricity mating key, describes why we like them I suppose of
our own brains! Technically only in Physics it workable with perfect alignments and precision hard lubed bearings, these just need more care is all. With a eccentric
drive, a strong point spring and not much lube and oilites..hmm.
The China one I kept, had a lousy external snap ring at the Top bearing, I could not live with, so I simply used the original in its place. If that bottom swirl groove
is gone that throws the oil back out of the dist. is missing, it is because it's simply worn off. In the bottom new bearing you replace, drill the holes through the
new bearing and the engine lube can do the job, but you need that spiral groove also and it was cut with purpose in a direction to throw the oil out of the Distributor
based upon its own rotation if you think about it and hold one in your hand and just turn it wise as it goes.
