Cleaning The Sherman 54B Filter
8NChris
Digger had the typical sluggish symptoms of a restriction. Didn't realize the old unit would work so well. Next up I will be taking the pressure relief valve down for rebuild if possible.
Pictures
(quoted from post at 00:25:05 10/12/19) Digger had the typical sluggish symptoms of a restriction. Didn't realize the old unit would work so well. Next up I will be taking the pressure relief valve down for rebuild if possible.
You might want to consider replacing that with a modern SS wire mesh tank strainer:
In-tank wire mesh strainer
External Spin-On wire mesh strainer with 5 PSI bypass
I have used the Zinga 100 mesh spin-on's with good results. If you add a $10 vacuum gauge to the filter head you have an easy way to monitor the condition of the strainer media and identify when it starts bypassing and needs to be replaced/cleaned.
TOH
