I have a 3 wire Delco 10si alternator on my tractor and the volt meter has dropped from 14 to 12 volts when running. I assume the problem is in the voltage regulator inside the case. I went on Ebay to find a rebuild kit but all the kits there are for 1 wire alternators! I assume the voltage regulators in the kit is different from mine. Is there any way you can use the 1 wire kit to rebuild a 3 wire alternator? Why are there no 3 wire kits shown?
What is the difference actually in the internal parts between these 2 alternators? Is it just in wiring inside the case? Please educate me!
