I purchased a set of spark plug wires for my 2n without looking at how they are installed. I see a pipe/tube bolted to the top of the engine and the individual spark plug wires are sticking out holes along the tube over each plug. The holes look to small to even fit the ends of the wires into let alone figuring out how to feed them through the tube to the distributor.
Question is, can I zip tie them to the tube and run them to the distributor without figuring out how to feed them inside? Sure seems this would save a lot of time and headaches.
Thank you,
HT
Thank you,
HT
