1952 8n hydrauLic
Mcwashburn06
New User
I used heat to change the position control pin and doing so I heated the springs next to it and shrunk them. I am wanting to get new spring. They are the position control spring and the constant draft control spring. Any advice
My advice is Don't heat springs with a torch!
Salvage yard or someone on here may have a spare top cover laying around with some good springs.If you knew the diameter,length,wire size and tension,you might find a compatible replacement.
