NAA Adventure
Hobo,NC
Location
Sanford, NC
What do you do during a hurricane they stop the show around here most are gluded to the tube for 3 days waiting for the hurricane...
This Jub showed up last week the story goes he took it to a guy to have it rewired and a few other things repaired 10 years ago the guy never finished it. I should have took a before pix 3 tires and rims bad so my first project was to take the tars off a junker so I could roll it...
I was told it was pushed outside 2 years ago the engine was stuck so I venture to un-stick it... I pop the plugs out I do not see any rust. I oil it down then swap tires from a junker to the jub this was a all day event... Next day I take the starter off use a pry bar to turn the flywheel and EX as pie it frees up : )...
Day 2... The oil filter had been removed I spec to do a rattle can restoration dirt dobbers has plugged the spin on filter adapter up... I removed it cleaned it up and for the ell of it put a battery in it and spun the engine oil squirted out the oil filter mount and plenty of it... I drop all the oil drain plugs I got 1/2 gal of water out the hydration sump and some from the trans and diff drain...
I am glad I drained all the fluids...
The carb had completely been taken apart so I put it back together. The ignition system had been taken apart so I put it back together... I was working toward getting it to run so I could evaluate it and give the owner the bad news...
Day 3 I do a bunch of little things It fired up runs good everything works as it should other than I have a issue with the carb it will not run with out plenty of choke but choked it runs out good. I got to get back into the carb and see what I missed... I drove it its a nice tractor almost makes me want one...
He's into me for about $1000 it will need anther $1000 with tires etc... You never know I would have wrote it off as junk...
Well if he pays you what you got in it your gonna be in tall cotton.
Did you get much rain out of that storm?
