2N REAR 28-INCH WHEEL CENTER DISC SWAP
My hat rim center disc's are rotted away, along with the rims. Can the 8n style 8 bolt hubs and wheels be adapted to a 2n? I am having a hard time finding replacements. I guess there are no aftermarket versions of these?
(quoted from post at 21:06:17 09/05/19) My hat rim center disc's are rotted away, along with the rims. Can the 8n style 8 bolt hubs and wheels be adapted to a 2n? I am having a hard time finding replacements. I guess there are no aftermarket versions of these?
You need the early centers. Lots of good used ones on Ebay for about $40 each plus shipping. Loop rims can be purchased new and will interchange with the hat style rim.
TOH
A 28" Rear tire and rim "6 LOOP" from a Ferguson 28" 6 loop fits a 2-N..
I made the swap last month.....
I was able to purchase a Ferguson parts tractor for less $$$$$$ than purchase rear tires and rims...
Bob...
9N/2N center discs and wheel hubs are not the same as an 8N and will not interchange. The rims are all the same -28 x 9- but the centers are not. The newer 6-loop aftermarket rims can be bought at Miller Tire too. I have a set of nicely restored OEM 28" Hat Rims with either 9N/2n centers or 8N centers -your choice. Email is open.
Tim *PloughNman* Daley(MI)
(quoted from post at 20:43:35 09/08/19) Today there is someone with 4 listed for $70 each. I don't see the ones you found. What did you call them?
Search for "9n rear wheel center"
dhusedtractorparts has several listed
TOH
Thanks. Didn't try wording it that way. Used the words "hat & hat rim, inner, middle" in various combinations because I saw them called
that elsewhere.
