9N oil pump rebuild
Lhaley
New User
Rebuilding a 9N oil pump an purchased a reaming tool and kit. Does anyone have the instructions that goes with the reaming tool kit? Thanks, Lhaley
(quoted from post at 20:27:40 09/04/19) Rebuilding a 9N oil pump an purchased a reaming tool and kit. Does anyone have the instructions that goes with the reaming tool kit? Thanks, Lhaley
1 - remove old bearing
2 - using alignment tool provided with kit bolt guide block to face of pump with hole centered over bore in pump body
3 - remove alignment tool and from backside drive new bearing into bore in body of pump. Do not disturb position of guide block in the process.
4 - insert reamer into guide block and ream bushing to size
5 - remove guide block and install gears
TOH
TOH
