Hi all, I have a rough running tractor, that i would not guarantee to start each time i try to start it.
It is an early 8n 6volt front mount. It has been giving me fits this summer. earlier this summer it would run great then after about an hour would sputter and die. I
checked for spark and found none. I had battery volts at the top of the coil or about 4 volts depending on the position of the points i guess. That lead me to a full tune
up. since it died after an hour i replaced the coil (now I have 2 good coils) condensor, points, plugs (autolite 437), plug wires (TSC generic kit). went through the 10
tips. I noticed that the clip inside the distributor was allowing the distributor plate to wiggle so i replaced that and now its tight. All this and I have good spark that
will jump about the 1/4 inch on the tester.
So, I crank and crank and it fired up and ran good for 1 minute then would die. let it sit, repeat. Pulled the sediment bowl cleaned the three screens, cleaned the carb. I
crank and crank and it runs decent and able to mow with it. it will mow ok then kind of loose a little power and run a little rough at times. So it isn't consistent and it
definitely has run better especially considering all of the work i've done I would expect easier starting and smoother operation that I have had before.
I notice that to get it running and keep it running, I have the main carb needle to about 3 and 1/2 turns out. the side pointing needle does little. The low idle is ok but
probably a little fast. I took the carb back apart and sprayed everything out and same thing.
It does take a bit of cranking to start, maybe a several cranks. (which i seem to have to use a battery charger everytime to get this machine running)
Does this sound like a carb issue? I just cant seem to make it through all the carb adjustment steps. once i get under 3 turns on the main needle it will die.
Also on a related question...how much play should the distributor cam have once the male tangs are inserted in the engine? the distributor itself has no side to side play as
the bushings are not that old. but I notice that when installed i can kind of rock the rotor back and forth maybe a 1/4 inch back and forth. I was wondering if those tangs
are too worn out and if that much play would affect the timing.
But I think my rough running issue is the carb having to be more than 2 turns out....any suggestions? I did not replace any jets during the carb cleaning. I just had this
fear of messing that part up.
thanks Rob
thanks Rob
