Powerstroker
New User
Hello all. I have been reading here for a long time and have great respect for all the knowledge shown here. I own 9N141273 which seems to be a 1940 9N. The last time I ran it I could hear a clinking sound coming from the engine area. When I parked it I found I could wiggle the fan and pulley quite a bit and saw a drop of coolant fall. So I am assuming the water pump needs replaced.
I have a service manual which gives the following steps.
Remove steering wheel. Is this necessary if 2 people lift the hood off. Also does it require a special puller.
Remove battery. Remove gasoline line.
Remove bolts holding hood in place. I find the dash bolts easily enough but have not found the front ones.
Lift hood off. Drain cooling system. Remove radiator. Loosen fan belt. Remove fan..
Remove water pump.
Have I missed anything so far? I am not really mechanical minded but do attempt some jobs. I have a friend that is a pretty good mechanic and he will probably help me.
Also, is this site the best place to buy a water pump?
Thanks in advance for all comments and help.
Marv
Not necessary to remove hood. Remove fan - 4 bolts. Slide fan forward to rest in the shroud. Loosen and remove fan belt. Remove water pump.
hi marv, and welcome :)
if memory serves me, the steering wheel is a much bigger pain when u go to put the hood back on than when u remove it.
don't worry about the front hood bolts. remove the single bolt at the bottom of each dogleg (the side pieces,) and they, the grill, and the hood/gas tank come off as a single unit. remember to watch the sediment bowl while you're moving it all around. also, if u have headlights, be sure to disconnect the wiring to them first.
Thanks for the replies. Not removing the hood sounds like something to try.
Is this site the best source for a new pump?
Powerstroker,First your SN 9N141273 show that you have is a 1944 2N.
You can change the pump without removing the hood as HCooke said or go through a lot more work and remove the steering wheel hood,and radiator/shroud,and fan to make things easy to get to.
Powerstroker,You ask is this site the best place to buy a new pump?
It
Yes it is and it also helps support this great site.
I have replaced water pumps on 8n's without removing the hood. On the 9n and 2n. The hood will not come off without first removing the steering wheel.
[i:051d12177d]"On the 9n and 2n. The hood will not come off without first removing the steering wheel."[/i:051d12177d]
i've had the hood of my 2N off twice. i have not removed the steering wheel.
