TheOldHokie
- Location
- Myersville, MD
I need someone with an NAA to test this power beyond block for me. It replaces the NAA-476 accessory plate under the seat and gives you two hydraulic ports for plumbing in a remote valve. All I am looking for is someone to install it and verify fit, normal 3pt operation, and check for leaks with the 3pt chained down. No modifications to the tractor needed, less than an hour's work, and the guinea pig gets it for cost if it passes muster and he/she wants to keep it. Only one pig needed so call me or send email if interested.
TOH
PS - pig needs to have a tractor with pump that can make 1600 PSI or more. I will provide the gauge and test connections along with the block.
[email protected]
301.655.0631
TOH
[email protected]
301.655.0631
