lift not working right . removed cover cam follower pin worn in half replaced replaced o ring on cylinder also changed fluid also. now lift wont raise. if you lift the lift arms halfway it will lifr on up. then when you let them down it wont lift again. was not like this before couldn't get full travel . is there some other adjustment I need thanks
Remove the right round side cover and see what the control arm is doing with respect to positioning the pump control valves.
(quoted from post at 08:30:42 08/26/19) It is in the hole and looks to be moving as it should
rm should push socket all the way up against casting for lift.
ok thanks for the answer and picture. think I have it now . loosened the 4 bolts and moved the up and doen lever assembly to get full lift seems to be a lot better thanks.
(quoted from post at 15:35:54 08/29/19) After doing all of this and adjusting lever that moves lift put on my box scrape and it works great thanks for the help.
ou are very welcome....glad works for you!
