Sorry couldn't finish was needed else where, so where was I, so if I want any speed I have to hold the throttle lever, need a new one. So everthing seems to be running good, 21 lbs. oil pressure cold idle, 18-19 lbs. hot idle. Its very eager to start, last time took me 4 tries, 1 cylinder would fire which dropped out my starter, other than that time no problem. Changed upper rad hose and stat, lucky it did no blow, when I took it off it was more like a sponge hose, nothing left to it. Went to get one, no one had one, had to order, crazy price, went to auto parts place, with the help of a great counter person went through the rad hoses they had there, found one with the right diameter and length from a G.M vehicle, cut it to length put a little silicone grease on the stat, pushed as far as I could, put it on the upper rad outlet on the head, which pushed it up the rest of the way, a few hose clamps good to go. So being the city slicker that I am while I was cleaning, noticed what looks like a type of hitch under the rear end, has a type of spring loaded pin at the end that pushes up, what is it, purpose, just wondering. Until next time, everyone have a great day.
