Is there a way to check the water pump on my 1950 8N 12 volt side mount while it is still on the tractor? I have pulled the radiator and am replacing the radiator, upper & lower hoses, filler cap and thermostat, but I would like to be sure the water pump is working properly WITHOUT pulling it from the engine. Can some of you gurus think of a way to test it and make sure it's pumping water before I put it all back together again? Thanks in advance for all replies!
RUHokie
1950 8N s/n 8N302363 - 12 Volt - Side Mount Dist.
RUHokie
