I put the 2n starter on my 9n. It had worked on 6 volts when I tested it off the tractor, but not after I installed it on the tractor. I then powered the starter with a 12 volt battery and it works good. Rolls the engine over very well. Is it a 12 volt starter? maybe I still have a bad ground?
I found another starter, but the shaft was bent. I attempted to use another armature to make it work and it does, after some modifications. I think that the drive gear is to close to the end flange. Does anyone know the distance that it should be? I have about .48 from the end of the pilot on the flange to the front of the drive gear. Can I lengthen the shaft to get the right clearance? After playing with these starters all afternoon, I did not feel like pulling the 2n starter off the tractor to measure how far back the ring gear sits.
TY
SDE
TY
SDE
