8N clutch shaft
Greg NE
Location
Duncan, Nebraska
I'm working on a late 8N that has a Sherman combo in it that had the mounting plate come loose from the transmission. I'm trying to get the clutch shaft out so I can remove the Sherman and tighten the mounting bolts properly but the pin in the fork absolutely refuses to budge. I have tried some heat with my torch set but that hasn't helped yet. Is there any tricks or suggestions any of you could let me know about or something I'm missing? Is the pin tapered or something? Thanks in advance!! Greg NE
