Company Logo Shop Now
TractorLinks.com
Sherman combo
Paul Humphrey
08-13-2019 16:21:49
I just bought an 8N that has a Sherman combo that won't go into the high side.Apparently the shifter mechanism is worn enough that it won't slip all the way back to engage.Anyone know if I can get at the shifter by pulling the top off the transmission housing instead of splitting the tractor?
Kirk-NJ
08-14-2019 00:36:40
 Re: Sherman combo in reply to Paul Humphrey, 08-13-2019 16:21:49
Here is a combo I took out of a 640 basically same as 8n
Kirk-NJ
08-14-2019 00:32:45
I have removed the top cover from the sherman thru the steering box hole once. It was a fight. As others have said a split will be easier.
Mike Groom
08-13-2019 17:07:12
Paul,I just split a Jubilee to fix the Combo Sherman that would not shift,turns out it was a worn ball bearing in the shifter mechanism,I think it was a 5/16 if I remember right,you should just split the tractor,it was only a half a day job from start to finish.
Paul Humphrey
08-13-2019 16:58:00
Thanks Den...............I thought that would be the case,but wasn't sure.I've had a lot of experience with 9Ns and 2Ns,but this is my first 8N.
Thanks again
Paul
Den N Ms
08-13-2019 16:34:55
Paul,Yes you can get at it by removing the steering cover of the transmission.But if you need to disassemble more than the top cover of the Sherman for repair it will need to be split.I would split it in the first place as that is just about as easy as removing the dash and box.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
