Furgeson t30
lrry2
New User
Hey guys did a conversion to 12 volt on
the t30 I installed a ballist
resistorthe voltage at the distributor
reads the same as the voltage before
the risistor should it show a lower
voltage at the distributor any info is
appreciated thanks larry
If the breaker points are not closed there's no current flow in the primary circuit and the voltage reading will be the same on both sides of your resistor.
