NoMoreCash
First of all I have been scouring the threads on compression tests and trying to figure out what I need to do for my old tractor. Lots of data and information but hard to piece it together. I have a 9n that was running fairly well but then started to miss and has no power, it was on the weak side to begin with. Figuring it was time for new points, condenser, plugs and spark Wires, I change all of these with no change in the performance. So I did a compression test and had these numbers. Dry #1 - 65, #2- 97, #3 - 87, #4 -95
wet was 75, 102, 115, 103
My question, is this indicating a valve problem on Number one and does Number 3 look like ring problems? if so what does it entail to get it fixed? Thanks for any and all help ahead of time!
