CheshireNic
New User
Just moved to a new property and it came with an 8N in good shape. Don t know the model year but it has the 12 volt conversion with side mount alternator. Took it for a spin and noticed that fan belt was torn up and hanging on by a thread.
Took the old belt into auto store and they matched the numbers on it to a "15417AP" measuring 3/8 by 42 1/4"
Got the new belt on and headed for another spin. It snapped within 5 minutes. Was able to get the tractor back before it got to hot but now wondering what went wrong.
A few things worth mentioning...did a lot of research on the forum regarding the correct fan belt size/length. Seems as though a 5/8 by 41-46" are used depending on model and alternator/generator set up. At 42 1/4 I could barely get the belt on and alternator was snug up to engine in order to get it to fit. The belt had some play once attached and seemed snug. 1/2 inch is recommended and I didn t measure but I would say it had no more that 1/2 inch play max.
Here are my thoughts/questions and I appreciate any incite from y all...
Not sure what size I need for my setup. I matched what previous owner had on there but maybe it was to tight/small to begin with? It was also a 3/8 belt and everyone recommends a 5/8? What belt size would be best with my set up? 12 volt 8N with side mount alternator.
Grease/W-D 40 on pulleys once I get a going? What do you think? Just a smidge?
Im paranoid the crankshaft pulley was not turning now. I just remember not being able to get it to spin during install. Alternator and fan pulley turned freely but I kinda overlooked if crank shaft was turning. Would it even turn with engine off?
Thanks folks.
Thanks folks.
