Company Logo Shop Now
TractorLinks.com
Order Ford 8N Parts Online
Discing with 8N
truckfarmer49
07-11-2019 16:43:47
I've been discing at a bit lower than full throttle.
Can I just go to full throttle and pick an appropriate gear?
Or is that to much to sustain?
Things sound okay though when actively discing with full throttle, long as I back off throttle before putting the clutch in...
Any thoughts?
(max throttle set around 2200 rpms)
JMOR
07-12-2019 12:46:01
 Re: Discing with 8N in reply to truckfarmer49, 07-11-2019 16:43:47
Quoting Removed, click Modern View to seemy 8N throttle is digital.......idle or wide open!
jon corbett
07-12-2019 03:36:55
like ed says
Greg NE
07-11-2019 19:58:27
We didn't do tillage work with our 8N anymore by the time I came along but in the field pulling, we ran our 5000 wide open. Most PTO work was done at rated RPM except for grinding feed and chopping silage which was wide open also. No offense to Indiana Ken but my Dad never wanted a tractor run at full throttle on the road, said it was hard on the engine as it wasn't under a hard enough load. Still have that 5000 and I personally know it has over 20,000+ hrs on it by now. I will admit that it needs an overhaul by now but it still runs good. The 8N did mowing duty and other PTO work mostly. Sorry for long post but I would say if your tractor is in good shape you should be fine running at wide open if it's not too rough. Just my 2 cents worth Greg NE
duey
07-11-2019 19:09:06
I don't run MYSELF at Full Throttle and seldom ask my equipment to do the same... It is in YOUR hands....
Indiana Ken
07-11-2019 18:28:26
We had an 8N - it was the only tractor on a 80 acre dairy farm when I first started driving. Later dad bought another tractor but the 8N still worked full time during the season. The only time we used full throttle was on the road. For belt work (grinding feed with the hammer mill) dad used 2000 RPM. PTO work was at 1500 RPM. Field work was between 1500 to maybe 1800. We never worked the tractor in the field at full throttle. Dad told me some people do but we don't.
The tractor is not going to break running at 2200 RPM but it is much more pleasant listening to the engine at 1750 on the disc than 2200.
John in Mich
07-11-2019 18:15:06
Growing up we ran the '51 8N WOT except with PTO implements or when cultivating young corn or soybeans.
You have to know, with a Sherman Combo, this kid always ran WOT on the road. LOL
Have to tell you that the engine has been rebuilt 3 times since it was new.
Ultradog MN
07-11-2019 17:57:05
When I was in AG IV class in high school our teacher told us these old tractors were built to run WOT all day every day.
Of course you don't Have to run them like that but you can without hurting them.
Ed S. (IL)
07-11-2019 17:10:04
Depends on how rough your ground is. I plowed down 8 acres last fall and had to disc in 1st gear the first pass. By the third pass, I was going in third gear. I usually set my throttle so it's pointing at the second screw on the quadrant.
yootoob vid
es
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
