Kirk-NJ
Finished up the 9n V6 conversion. Has sherman OD,not that it needs it. Straight pipes sound awesome.
<a href="https://imgur.com/2YF5EGf">
2YF5EGfl.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/DQkjUAX">
DQkjUAXl.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/AqtZ9Ie">
AqtZ9Iel.jpg" title="source: imgur.com"
</a>
Kirk,[b:29d205ef23][size=18:29d205ef23][/size:29d205ef23]Help![size=12:29d205ef23][/size:29d205ef23] no [size=18:29d205ef23][/size:29d205ef23]Brakes!![/b:29d205ef23]
Very interesting build! Doesn t look like you had to extend the hood but you to move the gas tank. Aside from the tank what other modifications had to be done? Fuel injection or carb? Serpentine or V belts?
Serpentine belt. Four barrel Holley carb. No engine alterations. If it
was an 8n I could have snuck a couple gallon tank under the hood
above the battery.
I should say I did have to remove the fan and install an electric fan
and install a low pressure electric fuel pump for the tank.
Have fabricated them in the past. this ones for a 2.8 chevy V6.
<a href="https://imgur.com/lDYwNHp">
lDYwNHpl.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/PZkaUe0">
PZkaUe0l.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/lVDzz4T">
lVDzz4Tl.jpg" title="source: imgur.com"
</a>
