I am struggling getting my front mount 8N running right. I switched to a 12 volt system about a year ago mainly because I could never get the 6 volt charging system running( I tested the generator, polarized and switched regulators). So the tractor kept dying and I was constantly charging and frying batteries.
So anyway, got all new wiring, alternator working and tractor firing I kept the original OEM resistor but did not add the secondary resistor because when I put in the secondary, it would not fire.
So you know the story. I've fried a couple square coils and I fried the OEM resistor.
The secondary resistor that came with my 12V kit is 6ohms which is too much.
At this point, I have a new coil with 2.5 Ohms, an OEM resistor which shows no resistance because it is not hot. I fired it up just to hear it run, and ran like a champ. Turned it off immediately.
My problem is this. I have read several threads about ohms law and testing procedures it is beyond me. I am older, stupid and my meters are not reliable on the ohms scale.
So my approach, is to add a second resistor that will give me the most resistance to protect the coil and let the tractor run. The 6ohm resistor is TOO much. I was going to buy a 4ohm, 3 ohm and a 2 ohm resistor. Try the 4ohm first and if it works I am done. If not, then drop to the 3ohm and then the 2ohm if needed to make it fire.
I do not know where to buy the resistors and when I have looked on ebay, the resistors also talk about Watts. I do not understand electrical so I don't get it.
Where can I buy the resistors I need and what wattage should they be if it matters?
Thank you,
Electrically challenged Obie
Thank you,
