Howdy all. It's been quite a while since I looked at this board, but now I have a few questions please. I have a '52 Ford 8N and I just finished the good old 8n throttle plate repair including new ball. (Thanx Bruce Haynes for your instructions in 8n Newsletter.) During reassembly I noticed that the throttle rod and bottom bracket seem to have some play in them. I would say about 20-25 degrees of slop total. Is this normal? The 1/4" bolt is in the notch in the throttle rod. I did not change it. I ask because when I tried out the tractor upon completion it twice dropped almost died but I was able to choke it and keep it running. (It runs lean so I have part choke on it). That's to be fixed later. It only drops off like it's going to die when going up hill, so a slight load. I did not touch the governer compensating spring.
My other question is about the throttle spring attached to the bottom plate. It is there, but doesn't seem to do much. It is under slight tension at no to low throttle and actually does nothing as throttle is increased.
Any ideas?
Any ideas?
