Anyone want to repair a hat rim?
Lynn Patrick
Lynn,It looks almost as thin as a piece of paper and was treated kinda rough getting the tire off of it.I have repaired my share of them,mostly a 3" band welded around the inside where they rust out.I would pass on that one!
Lynn,Hobo on here has/had a pair that he refurbished if you want to keep hat rims on your new to you tractor as they are getting harder to find GOOD ones.You might check with Hobo.
Too bad you're not closer, that'll buff right out!
Cut two bad rims in half, weld them back together being careful
not to warp them, drill a new valve stem hole, have them balanced
without the tires. Add weight by adding interior weld where needed.
Polish, paint, mount the new tires and rims and you're good to go!
Four bad rims total would be required to complete the operation.
I'm not saying I actually did this, it's just a theory. LOL
But I'll see your hat rims and raise you a set of power adjusts!
Have repaired several myself and was in your town this afternoon and could have taken a look. The picture is leading me not to come back
I've got one off a 2N that the rim itself is good but needs about 1/3 of the inner band replaced,any takers?
I'm 100 miles west of the Mississippi. A little much traveling for a unusable rim. Thanks anyway
This tractor won't be all original when I get thru w/it, but should be ready to work, so won't be getting hat rims back! As it is now the other rim needs work, but I'll decide if I'm going to repair or replace when I get the tire off. I have 2 loop rims waiting to be used already.
But thanks for the offer!
