Ford 8n no gas in back 2 cylinders
What do you base that assumption on? Have you done compression check? does it run? if it does, maybe the front two are not firing and appear wet with fuel.
(reply to post at 16:08:51 05/15/19) [/quot. Number 1 and 2 cylinder r running. Plug looks ok back to have spark and aren't firing. Pull wire off spark plug when running motor doesnt change .they have good compression when i checked. Ran good last fall
Is thing to do is verify that wires to 3 & 4 are not swapped. If ok, then move plugs from 1 & 2 to 3 & 4 & visa versa.
(quoted from post at 16:30:41 05/15/19) Is thing to do is verify that wires to 3 & 4 are not swapped. If ok, then move plugs from 1 & 2 to 3 & 4 & visa versa.
plug wires r correct and put new plugs in it. Isnt the firing order 1243 on the 8n ?
(quoted from post at 19:38:52 05/15/19)
es, just like the drawing shows. However, since you have the drawing in front of you and still ask, that may suggest that you do not understand?
For grins I would swap #3 and #4 wires and see what happens. You have nothing to lose! Do you have a front mount 8n or side mount distributor?
